SLIP Dakrside tire on a ST W\O soap.
OK yea we can pry kick twist and soap the tire to get it to slide in but how about Plastic.
RedST05 took the pictures of his install after I showed him this little trick. Make sure to angle the tire so it gets past the center of the right drive. You can also put plastic on that side to make it easy to put the darkside on a ABS to.
Thanks to Guy for the photos.
Photo #1 shows where to put the double layer of plastic.
Photo #2 shows the plastic folded in half and being slid in.
Photo #3 shows the tire starting to slide by the swing arm.
photo #4 shows almost all the way in.
photo #5 shows the plastic falling away as the tire rolls in.
No I'm no pro at this stuff just had no soap when I went to install mine.
:ds1:
:ds1:
